+1 with yendor
“The best way to cheer yourself is to cheer somebody else up.” - Albert Einstein
+1 with yendor
http://www.nissanpatrol.com.au/forum...3&d=1347939022
Is the Black on the right side of this plug in the picture on the right the earth and not the green and yellow stripe?
Mine is exactly the same. If i measure with a multimeter at the moment, with a filament globe in the socket. From the side of the globe to the chassis is a direct connection to earth. Meaning the centre would be +ve yeah? And that's how it should be right?
If i cut and swap them then the centre of the socket would become the -ve and the side of the socket the +ve. To me that would be wrong. As you say a filament globe would still work, but if all the other sockets on the car are wired the same why do they work and not this one?
Continuity from side of globe to chassis is 0.00 earth. And A normal globe works fine. But swap the globe for an LED and i get nothing. If the side globe socket is +ve and it is a direct connection to the chassis like people are saying they have to change to then, wouldn't the whole care become live??? And then short out?
My way of thinking you can't have one socket wired one way and another the opposite when they are powered in the same system or circuit.
The socket is above ground it mounts into a plastic light.
I think you will find you are getting continuity through the bulbs.
Measure the voltage across the socket and pay attention to the polarity of the readings.
Yep got the wrong reading before. Took the globe out and measured the continuity from the centre of the socket to the body of the car and sure enough it's been hooked up opposite to the whole car. Thanks for that Yendor.
Now for the quick snip and rejoin.
Also for those in this position. This is if you have steady hands and a little patience you can actually swap the red and black wires in the plug itself. There fore no cutting or re-joining like i was going to do and everyone has probably done.
Upon looking at both plugs and a little poking with a little hook/pin tool i had, You can actually pick open a cover exposing the bare wire terminals and gently push them out, swap them over and push terminals back in until they clip back into the plug.
Then gently, in the reverse to opening the little cover, clip it back into place.
Now once you have put it back together, either globe will work no problems.
*** http://www.nissanpatrol.com.au/forum...cons/icon4.pngPlease note that in the pictures below I have already swapped the wires. So looking at the last pic and holding the plug as I am, red on the left black on the right is what you should end up with if successful.http://www.nissanpatrol.com.au/forum...cons/icon7.png
