Crankshaft
The way they look at airflow on aircraft is to simply tape 6" pieces of wool to the surface and watch it. From that you can gauge a lot about airflow.
I keep getting told that louvers won’t work and won’t help but there is a lot of heat trapped under the bonnet. To get away it must be pushed down and under the car leaving a pocket of hot air under the bonnet and heating the rest of the floor. I can see why vents in the bonnet may not work in a performance car with a sloping bonnet and an air dam as that generates a negative pressure under the car and helps the airflow from the radiator and under the car.
But Red is as far different to that as is possible.
So I need to identify the low pressure areas on the top of the bonnet and I suspect they are on the side and then set up some sort of venturi extraction vent.
Hopefully better flow through the radiator and conductive cooling direct from the engine.
If nothing else it will be interesting..
