Have been using LEDs for around 6 years now. They have improved a lot over that time. For general lighting I find warm white more pleasant than cool white, & these days prefer the smd strips that others here have used. Fwiw I find that if mounted out of direct line of sight where possible, or behind diffusers they are much less dazzling. I haven't tried them with a dimmer yet though. I've converted several fluoro lights to led simply by removing the fluoro tubes & replacing them with a strip of thin plywood with the led strips stuck onto it.
Cuppa
You can get LED tubes. Take the starter out if the fitting and pop the LED tube in. Pricey through at $40-60 a pop
DIAL-A-TAP
