Awesome thanks heaps for all the info guys i do appreciate it as im a very novice mechanic, will put the new master on purchase and see how we go fingers crossed
Sent from my CPH1701 using Tapatalk
As above, but go ahead and use the air compress on the line when it is disconnected from both ends, then flush it out thoroughly with fluid before reconnecting it.
Considering there appears to have been a blockage (more than likely though at m/cyl), but to prevent any crud at all that may be present in the actual line from plugging up with the force of the compressed air. It maybe safer to first attempt a flush thru with brake fluid using the m/cyl then air and back to fluid to get rid of any moisture from condesation?
Just picked up my new master cylinder $115 will pur it in this arvy and see how we go
Ok guys so update is i got the new master cylinder in i can get it to the point where there is about 1 inch of pedal on the clutch but if i leave it in gear with the clutch in he car starts to creep fowards and lose the clutch but if i rake it out of gear then select it its ok still only little clutch and starts to feel abit crunchy three quarters of the way down nothing like it used to be?
Have you bled the air out of the system?
Did you prime the master before fitting ? How is the flex hose , does it bulge when the peddle is pushed , did you bleed it at the slave ? Is the slave doing it's thing ? That gunk will be in the whole system .
