check out the size of my zucchini
Attachment 74585
Attachment 74585
http://www.nissanpatrol.com.au/forum...018/02/160.jpg
http://www.nissanpatrol.com.au/forum...018/02/161.jpg
http://www.nissanpatrol.com.au/forum...018/02/162.jpg
Well it is Mardi Gra time in Sydney and I was just wondering what float you're going to be on this year Avo ?
War of brands
Attachment 74699
A new portion of brain degradation is already here!
Attachment 74707
Attachment 74706
Attachment 74708
It was made so we could seperate the good politicians from the asses but it was soon discovered that they were all the same so the machine no longer gets used .
Attachment 74776
Interesting roadhouse/tucker stop confusing me entry warning signage :-) http://www.nissanpatrol.com.au/forum...018/03/164.jpghttp://www.nissanpatrol.com.au/forum...018/03/165.jpg Decided safest to conceal my Dirty Little Harry before chicken breakfast :-) http://www.nissanpatrol.com.au/forum...018/03/166.jpg
Laws like that are so they stick their 44 Magnums in their belt under their shirt.
That way an accidental discharge blows their nuts off and one less Texan too participate in the gene pool
Just love Fannyshttp://www.nissanpatrol.com.au/forum...018/03/275.jpg
https://youtu.be/blaL64WbI2s
Needed now apparently mate, animal avoidance too :-) https://youtu.be/r0GfQPjJ1WM
Hmmm. . .
Wonder if whoever put that up thought "yep job well done, proud of that" [emoji6]http://www.nissanpatrol.com.au/forum...2018/04/79.jpg
For a short memory
Attachment 75041
It needs just 2" lift and it will do it next time, o ye!:bananarock:
Attachment 75267
Seeing those spare tyres in the mud reminds me of the exploits of Alby Mangles on one of his jungle escapades back in the '70's!
Is it a usual day in Sydney's suburb yeah? :tongue:
Attachment 75329
We’d all here much rather deal with them little pets WM mate, you’ve got Real Bears haven’t you :-) ?
Please be sure to not swim/bomb downstream of twin falls on your next epic FNQ adventure mate :-) !
Works for wet season hot water stingers too bad man :-)
Today reminds me of another royal wedding...his mother...Divorced a Prince, engaged to an arab and f##ked by a pole
LAB PROVES EXISTENCE OF DARK SUCKERS
For years it has been believed that electric bulbs emitted light. However, recent information from Bell Labs has proven otherwise. Electric bulbs don't emit light; they suck dark. Thus they now call these bulbs dark suckers. The dark sucker theory, according to a spokesman from the Labs, proves the existence of dark, that dark has mass heavier than that of light, and that dark is faster than light.
The basis of the dark sucker theory is that electric bulbs suck dark. Take for example the dark suckers in the room where you are. There is less dark right next to them than there is elsewhere. The larger the dark sucker, the greater its capacity to suck dark. Dark suckers in a parking lot have a much greater capacity than the ones in a room.
As with all things, dark suckers don't last forever. Once they are full of dark, they can no longer suck. This is proven by the black spot on a full dark sucker. A new candle has a white wick. You will notice that after the first use, the wick turns black, representing all the dark which has been sucked into it. If you hold a pencil next to the wick of an operating candle, the tip will turn black because it got in the path of the dark flowing into the candle. Unfortunately, these primitive dark suckers have a very limited range.
There are also portable dark suckers. The bulbs in these can't handle all of the dark by themselves, and must be aided by a dark storage unit. When the dark storage unit is full, it must be either emptied or replaced before the portable dark sucker can operate again.
Dark has mass. When dark goes into a dark sucker, friction from this mass generates heat. Thus it is not wise to touch an operating dark sucker.
Candles present a special problem, as the dark must travel in the solid wick instead of through glass. This generates a great amount of heat. Thus it can be very dangerous to touch an operating candle.
Dark is also heavier than light. If you swim deeper and deeper, you notice it gets darker and darker. When you reach a depth of approximately fifty feet, you are in total darkness. This is because the heavier dark sinks to the bottom of the lake and the ligher light floats to the top.
Finally, we must prove that dark is faster than light. If you stand in an illuminated room in front of a closed, dark closet, then slowly open the door, you would see the light slowly enter the closet, but since the dark is so fast, you would not be able to see the dark leave the closet.
In conclusion, dark suckers make all our lives much easier. So the next time you look at an electric light bulb, remember that it is indeed a dark sucker.
Attachment 75516
