Hi john, I'm having computer issues at the moment so ill paste the pics here.
Attachment 34754
Attachment 34755
Attachment 34754
Attachment 34755
There ya go. Winch bar..
Yours does wrap the chassis..
Simple plates for you my friend, will just have to get that 3rd nut..
Changing computer services ATM so using via my Smart phone.
What ARB did as those holes for recovery were tearing out they welded washers {thick ones} either side to beef them up'
But as Kallen says only one plate on drivers side unless you drop the bull bar.
ALso being non airbag you can drill and fit Two hooks on the uprights of the Cato straps But these will need to be braced with a fully welded backing plate.
Or drill and fit 2 x M24 Eye bolts in line with the chassis rails, worlds your oyster
OK, so I reckon I'll do the OEM hook replacement. That should do for now as I was going to drill holes for the M24 eyes in the bar as I have a pair of those sitting around.
How much for the RHS John?
Cheers,
Drew
Thanks TD, just ordered some recovery points. Cheers
Hi td not sure what happened mate but I'm keen to get some points off you and showed you those pics, did you work out what I needed?
It all went to poo when we had our meet up...
No probs will get it sorted , this is the picture of the one to suit the GQ,
You can also bolt a black hook to it if need be.
Edit or you could bolt one of these in line with the chassis rails on the
front of Bullbar either side of winch
@ MitchM these are the 2 styles I'm thinking will fit, the folded fit under the chassis rails and the other bolts to the outside of bulbar.
That hook one I've been using for years, had another on my other 4x4 as well great around camp and on the tracks for quick hook ups, but don't make them any more.
