Stropp
Replaced my electric antenna insert that I broke on the feral flats trip, old age I forgot to drop it prior to doing the bush tracks, what a mission, had to remove the whole thing from the inner guard and then dismantle the motor and remove the tube the antenna sits in as even though the instructions say you can push it into the top, there is a small lip that prevents you doing that so after a struggle managed to remove the tube and feed the new one up and then set the gear teeth on the retractor and reassemble the motor then test prior to reinstall in the guard, surprisingly it works ������ I forgot to take pictures
