PeeBee
What is also necessary to mention is that the alternator may be rated at 300amps, however its output is ramped up against the load, so for example, I had the car addling in the driveway this afternoon and it was outputting 12 amps. I checked with with another identical meter and a dc tong tester, and then when a load is applied to the system, such as headlights, high beams and one light bar the ammeter showed a charge rate of 35 amps. I expect my nominal amp draw to be around the 60 - 70 amps with everything running, fridge, headlights , a/c driving lights. What will happen then is the alternator has plenty of capacity to then idle away this load. Having the additional rectifiers on board keeps the heat load down per rectifier, hence their efficiency is increased, as is their life. It will be interesting to se how it performs under a winching load.
