http://www.c31.org.au/schedule/view/episode/96821
The Tower Brace segmentn starts around the 4.34min mark
So it does exist... :p
Meh........ I dont know what all the hipe was???
I'd love to see your Q in action, MR.
Mudrunner...one word for your car...AWESOME!!!!
And big too
But it dosn't have long arms :P
Yeah but does it need them???? ;)
Attachment 34899
Attachment 34900
Yes. It's so much better to drive not just off road but on road too. They help when climbing, they lessen the rear steer effect quite a bit, increase stability and also allow for more flex.
I just spent like 45 mins on the superior site reading up on them. They seem pretty awesome. Very good idea indeed.
link:
http://www.superiorengineering.com.a...ducts_id=20308
Yes the rear bushed joint is a winner for sure. That is straight from an 80 series front end design! On of the few things Toyota got right!!! Shhhhhhh! Don't tell anyone I said that! ;)
The Hybrid looks to be a combo between their Drop arms and the rear joint /drop box design. Looks good Bene! Will be giving them a good look at in October for sure mate
Ow ok.. Interesting.. I would have thought the Patrol pin setup would flex more than the opposing pin and Bush.
The patrols arms rotate easier, sure droop is not as good. The toyo setup would droop nice, but would struggle crossing up..
To me flex is the ability to cross axles, not straight drop..
They are 100mm longer than a standard drop arm and the rear bush change is to promote better bush life, as when your flex the pin type a lot the bushes flog really quick. The length helps with stability again and also flex while the 80's bush will give good bush life ;).
Also good flex isn't just about one side tucking hard and other dropped to its limits but good flex will allow the vehicle to stay level while the suspension goes through its travel. You want the suspension to do the work anytime your chassis angles over you have reached maximum flex and you have no suspension left.
So 100mm longer do you need to extend the front driveshaft or is this distance gain at the chassis end.
yes it is at the chassis end Mega.
If you have a look at this pic and note that the top mount is in line with the factory mount (in fact it connects to this position for strength) and the bottom mount is set 100mm back.
http://www.superiorengineering.com.a...s_pair_wat.jpg
and here is a standard Superior Drop Box. the top mount is consistent between the two pics
http://www.superiorengineering.com.a...0in)%20wat.jpg
http://www.nissanpatrol.com.au/forum.../2013/10/8.jpg
Isnt that last pic standard arms with a drop box
yes. It was the best pic i could find showing the standard drop box location position for the rear joint of the radius arm. you can see that a standard drop box just drops the pivot only inline with the factory setup. the Hybrid that Bene has sorted pushes that back 100mm below the gearbox support.
Couldn't agree more. Just in my eyes the patrol setup is like a pin in a sleeve, the arm will rotate all day long allowing good axle rotation.
I do agree anything more than 2" lift and the bushes are out of there range, but that's when drop boxes come into play.
As for the toyo setup, the arms will swing up and down all day, but as soon as the arm tries to rotate its very limited buy the Bush and pin.
It's like putting a bolt threw that pin and sleeve, that pin is only going to rotate as much as the slop (the Bush) allows.
I'm sure I'm wrong, but in my eyes the Nissan pin setup with drop box is a better setup.
Ahh ok yep
I don't see this mod giving MR an increase in performance over what he has now.
Yeah I am not in a hurry to change much now I don't thnk. Keen to see Bene's long arms in the rear though. newby's definition above is spot on and the flex pic of my car on the previous page shows a car sitting nice and flat and level and fully crossed up! I like it. In the car I really had no idea that it had crossed up so much until I got out of the car to take a look. I smiled ;)
Attachment 34934
Just cause I like it ;)
Your just as bad as that bloke and his pics of the things we sit in... :D
That's one beast of a GQ you have mate ;)
One hell of a truck mate
((35" Spring spacers)) can you recommend the best brand
Is this still around or has it been parted out?
I think that's why he drives a lot at night so know one will see him with busted CV's being towed by a Nissan!!!
