Very curious about this Phil. Did you use another washer bottle/motor for it or?
One similar to this I’ve seen done locally mate :-) http://www.nissanpatrol.com.au/forum.../2018/03/7.jpg20L tucked away for steepest emergencies can definitely work short term. Silvans ‘White’ version I believe can be used potable too?
Good for spraying weeds too
I personally prefer the 200L version out the back of our paddock Navara beast, keeps the wheelspin flames under control ! http://www.nissanpatrol.com.au/forum.../2018/03/8.jpg All jokes aside, blokes I know do benefit greatly from the 20L jobbies plumbed up for radiator emergencies ;-)
Not today but yesterday. Got the Patrol serviced and the water leaked fixed. I change my oil and filters at every 5Kin including air. Now that I have a company car I guess this oil change will see me til the end of the year. Lol. Took it it for a spin this evening, as I hadn't driven it for maybe 6 weeks. Everything felt so weird as Im used to driving a Territory.
I've sent it done a few times and the guys think it's definitely working when going gets tough !!
Last one I saw , the bloke re routed his rear window sprayer asembly to mist the radiator and the intercooler ... Not much water in there but in need it definitely can help.
I mean who the f... Used the rear washer anyway lol. Can't see the window and the thing leaks anyway.
It’s common for the guys with Turbo rice burners to put a spray kit in front of the intercooler
Mark, I have started out using a 2L washer bottle setup to assess its effect. In theory the spraying of cold water onto the hot coil will amplify the cooling effect as evaporating water releases energy, hence the coil will cool more effectively. What remains to be seen is the amount of water and the effect/time lag on anything tangible. Ultimately I will hook up a shurflo pressure pump into the 120L SS water tank I use around camp. For weekend trips I don't need that much water, mostly beer, so its a bit of an experiment right now, cost around $25 plus my time.
The system that @MB mentions is also worthwhile, as the system is pre-primed and at a higher pressure than the simple washer bottle pump. The key is getting the right droplet size and volume of droplets to contact the hot radiator. I expect to use this on long low range/high rev climbs only, then maybe some 'pulsing' at the top of the hills if the temps push over the 105 Deg mark. Unfortunately I have not found any realestate to install a silvan pump/tank set-up, so the shurflo and ss water tank will suffice. I did buy a cheap 12V solenoid valve for the instant cut-off in ebay for $6, so will see how that goes. I have tried to engage with a large spray nozzle manufacturer to select a nozzle, but the arrogant dick basically told me i wasn't worth the effort, so next time I have an industrial project requiring spray nozzles, he won't get a call - what goes around comes around. I keep you informed as this develops.
Over two days: Changed out both front rotors and pads. Greased wheel bearings, fitted new seals and fitted new wheel studs to P/S. Rebuilt D/S caliper and bled the brakes.
After at least 50000 ks, the Innox MX8 grease in the bearings was still very clean.
Had the master brake cyclinder replaced, recently.
Yesterday, I filled the water tanks up (90lts) ready for a few days away next week.
Still undecided if I'll hit the sand, dirt or bitumen! PML.
Well turns out I damaged an abs hose over the weekend....
http://www.nissanpatrol.com.au/forum...018/03/167.jpg
I know gq guys swear by braided line upgrades, but has anyone done it on a gu with much improvement? Otherwise depending on cost, I may just replace the damaged one with a oem replacement
Yes, me... and bloody well worth it I might add altho I was running 35's at the time
that looks like your abs sensor at the front there
What did I do to my Patrol today?
Sweet FA!
Why?
Cause, apparently, "It's a 1999 Y61 GU Patrol TD42 ST Series 1 Coil Cab Chassis" repeated twice is not a specific enough model description for the wanker parts interpreter to get me the correct F#%$^# bits!!!
FFS... time to have another Beer, watch the footy and consider in what order to dismember his vital body parts on Monday
Removed the alternator. I had to remove it with the mounting bracket that bolts to the engine block as the A/C pipe is about 5mm behind the lower mounting bolt so I couldn't remove said bolt. Lucky the bracket wasn't too hard to remove...
http://www.nissanpatrol.com.au/forum...018/03/197.jpg
Took the usual dargo shot...
Checked the Valve clearances on the TD42...as well as I could...lol...washed the dust from last weekend off.
Bought a spare steering box and cheap GME3200UHF together for $120 all up
Got it dirty [emoji4]
Installed a 'quick t verter' device to the charge circuit of the main alternator. Its a rectifier pack that splits the load across 18 diodes instead of the standard 6, hence allows for the rectifier diodes to individually run cooler and increases charge efficiency. What I have found since installing it is that the main battery voltage does not drop when on high beam, all driving lights on. Before installing it the voltage would gradually fall and the alternator could not keep up - is a small mitsubishi pajero 100amp unit installed by Brunswick Diesel as part of the Chev conversion. There is a bit of minor work to do to the alternator, but looks good. here is the link to the device. I and @MB have purchased the 420amp units. They don't boost the output, just decrease the load over more diodes. Both our Chevs run hot and alternator death has become the norm of late - hoping this fixes it.
https://alternatorparts.com/quicktif...rectifier.html
A successful day.
Installed the redarc gauge
Took it to the car wash to leave the mud behind.
Rotated the tyres well overdue, but it's now done.
Loaded up the trailer with all the bigger things that can stay in there for a few days in preparation for a Thursday night departure.
Fixed the Uhf issues, I hope.
And gave it a well deserved bath (between the showers) and vacuum.
Scrubs up alright. She'll be 21 towards the end of this year.http://www.nissanpatrol.com.au/forum...018/03/230.jpg
Replaced the damaged rear abs sensor after picking up a second hand part from patrolapart this morning
Just ripped out the cruise control vacuum/motor and the pull-cable all the way to the pump.
Gained ample room for the Catch can. Perfect spot.
http://www.nissanpatrol.com.au/forum...018/03/239.jpghttp://www.nissanpatrol.com.au/forum...018/03/240.jpghttp://www.nissanpatrol.com.au/forum...018/03/241.jpg
Cheers again Philstar for kindly getting these Quicktifier jobbies in mate! http://www.nissanpatrol.com.au/forum...018/03/243.jpgI’m running a bit behind your efforts mate but managed this arvo to bolt the 170amp GQTD42 alt back in after its birthday with 3 x phase wires at the ready! http://www.nissanpatrol.com.au/forum...018/03/244.jpg Just needs final connections now and away we winch/fridges/lights/fans galore up and running again for now ;-) http://www.nissanpatrol.com.au/forum...018/03/245.jpg
