give it a big hug now cause when it's fitted it'll be a bit of a stretch lol
troy
if you use a gasoline engine, you can use both LPG turbo or supercharger, the limit is on the technology they use, and of course the ability to regulate the mixing ratio.
today the option of mounting a modern V8, with a modern injection system and ECU open like Haltech or even MegaSquirt, is more than attractive.
I am sure a 2UZ-fe toyota engine does not have much trouble adapting to the gearbox of the patrol.
and if you use propane gas to run the engine not only have a fuel savings, but also extra benefits, like a more controlled combustion, better lubricasion cylinder and lower emissions
a greeting!
thanks for the info guys would be interested in doing the mod to my truck!
check out Efi upgrade in this forum.
