Lol yeah thats me. The plick in the USA shafted me hard after 6 years and a few thousand Dawes valves and now sells them to MTQ. I have no time to this pile of poo and would not give him the steam from my piss.
Fair enough mate, can you recommend someone at all?
Try MTQ for the Dawes.
Do you own https://dawes-devices.com Checked out MTQ they can go jump..not paying $120 just for a Dawes valve, Im after the whole kit.
I replaced the factory pipe from the air filter box to the turbo input today. It does away with the resignator box. Had to tweek the needle valve after this. What does the resignator box thing do anyway?
This may answer your question.... https://itstillruns.com/air-intake-r...-12156112.html
He’s the turd who makes them. I was buying wholesale from him, maybe 60 a month is used to sell. There is also the Tillix valve which many have had good success with. As for the needle valve. There’s a hydraulic mob in Adelaide who sell the Tognella needle valve that I use to sell. Can’t remember their name though sorry.
Sent from my crapPhone using Tapatalk
Bought my kit from this mob. https://www.tillix.com.au/product/bo...l-zd30-di-crd/
Just filled up first full tank since Dawes valve, Dawes needle, and EGR block off kit. I covered 1520K's and burnt 162 liters. That gives approx 12 liters per 100klms. That has been around town driving with the aircon on most of the time. Town is only little Alice Springs so there is very little stop/start driving. I'm quite happy with that.
Cheers all.
Hello all
I’m just starting out with all these modifications thanks for all the info would love it if you added some photos of work then can put two and two together.
I’m about to rebuild a zd30 that I got a month ago with a hole in no 4 piston had done 396000km so not a bad effort.
I have been trying to download manual for it but need to do more chatting then hopefully I can get one before I start rebuild.
Was wondering if there is a stronger aftermarket pistons available and if so where to get them
Thanks Mal from Alice Springs Also
@Malfunction777, best to start up your own thread and ask specific questions as you go. Help is here mate but we do not know how much you do understand. So many install options but depends on you proposed set up.
Wish I posted a mod build thread at the start, would be a good reference to trace progress of build mods and performance change over time.
Hey Mr Malfunction. I installed both a Dawes valve and Dawes needle valve. In the end I pulled them out and installed a diesel smart 20psi actuator in their place. Much simpler installation. But you can’t adjust anything once it’s installed. That doesn’t worry me yet. Hopefully it won’t. Cheers, Brian.
