Anyone know any good machining shops to do the head and the block for me. Also I won’t need to have the cylinders honed because I’m replacing the sleeves is this right
Where abouts are you mate, liners will need to be honed they don't come finished.
I’m in east and south east Victoria.
Ok awesome thanks I’ll make not of that
Any one who will not use liquid nigrogen to install your liners. Specify that. PRESS FIT ONLY. DON'T LET THEM TELL YOU OTHERWISE. specify it and even make them sign before commencing work.
Some people drop the liner the last few mm and that can and HAS caused tiny fractures around the fire ring. This can and HAS caused the liner to drop, this causes catastrophic failure. The piston goes down to BDC and drags the liner with it, forcing it into the crankshaft. This has happened and no doubt will happen again
Bloody hell will definitely make sure no liquid nitrogen and I’ll make them sign for it.
How do I know if they have used liquid nitrogen?
Don't think you could tell just have to take their word for it. There's a bloke in Clayton who is really good if that's not too far. . .
Nah Clayton is easy for me
Oh cool, Google go2 engines and give Omar a call see how you go. .
Spoke to go2 motors today and they said they freeze the liners before pressing them in. Also they won’t machine the motor if I am rebuilding the motor myself bc of warranty and the blame game that can come afterwards.
Hmm, could try Duggan engineering in Reservoir if not there's a couple of places in Bayswater but can't remember names. .
Liquid nitrogen is a problem due to the rate of contraction on the liner causing micro fractures thus weaking the liner
Placing the liner in the fridge or freezer prior to install is fine as the liner contracts in a much more controlled manner.
Ok that was my only real worry.
Thanks guys for clearing that up. I’m gonna be uploading some pictures of the motor soon and the whole process of pulling the old grenade out of the trol
Does anyone have any idea what socket to use for the end caps for the pistons. Can’t seem to get a good grip on one. A 15mm fits but i don’t want to risk getting stuck with a stripped nut
http://www.nissanpatrol.com.au/forum...018/03/205.jpghttp://www.nissanpatrol.com.au/forum...018/03/206.jpg
Got the motor and the block apart
Very good mate, did you take the head off in sequence of the manual?
Only reason I ask is that there's a specific sequence in undoing the bolts and we, I, some have not followed that before.
Yeah I followed the procedure as best I could
How's it all look, how many K's and whats the reason for rebuild? (Sorry might have missed some of it previously)
All good Rossco so basically I bought the motor off a mate it’s got 400,000+kms on the motor and the reason for a rebuild was I’ve always wanted to rebuild one so why not. Also would love to be able to turn the key and know how much effort I put into the motor.
Yeah nice sure it will come up awesome and should be fun, enjoy. . .
So the series of photos I am about to upload are from the crankshaft. 5 of them are fine one is not. I’ll let you guess which one
http://www.nissanpatrol.com.au/forum...018/03/231.jpghttp://www.nissanpatrol.com.au/forum...018/03/232.jpghttp://www.nissanpatrol.com.au/forum...018/03/233.jpghttp://www.nissanpatrol.com.au/forum...018/03/234.jpghttp://www.nissanpatrol.com.au/forum...018/03/235.jpghttp://www.nissanpatrol.com.au/forum...018/03/236.jpg
There is some surface contaminants on the others from being in the garage for a while but the damaged one I just took out.
Ooh ouch. . .
http://www.nissanpatrol.com.au/forum...018/03/237.jpg
The good one
http://www.nissanpatrol.com.au/forum...018/03/238.jpg
The shit one
Do you think they could save the crank shaft? Polish it out
Yeah bugger bet your glad it's getting a rebuild now. Had the bearing spun on the journal or just buggered? Expect it's a result of low oil or lack of oil changes most likely ? ? Looks fairly substantial, machine shop will know once it's measured or might have to be ground to see how much needs to be taken off to get it good again. Not sure what over size the bearings go up to will determine the repaiability.
I think that some debris or something had gotten into the motor and in the journal because they were in the right spot.
Yeah hopefully it can be repaired
Will I need o/s or u/s Conrod bearings?
Has anyone had any dealings with crankshaft rebuilders in Blackburn thinking about giving them a call but didn’t wanna waste my time. Open to all opinions.
Does anyone know the best place to source genuine Izumi or Mahle turbo pistons for the td42
Try this mob.
https://partsouq.com/
Thanks mark I’ll give them a bell
How’s your car going mate?
It’s been a little while since my last post but work has kept me from my patrol. So now the gruelling task of pulling the old motor and trans out is upon me and I have no idea where to start. Anyone have any suggestions.
Start with taking off the bonnet then just chip away at it. Label wiring to make it easier, if your air con is all working just unbolt the compressor and zip tie it to the chassis so you don't need to regas it. A few beers & tunes might help, enjoy . . .
He'll need to remove the a/c compressor. Cant use the ZD compressor on the TD. But as Rossco has said. just start unplugging the loom. But remove it entirely, it goes into the firewall and plugs into the ECU. As you will need to send that loom off to get converted, if your going that way. I did and it was easy. It came back and just plugged in to every it was supposed to for a TD42. You might need to contact killa kustoms about your loom as you are going from auto to manual as well.
After thats all out, its just a matter of disconnecting everything. Which wont take long. I reckon it took me an afternoon to totally remove everything on and around the motor..
Yeah thought that might have been the case, couldn't remember what the conversion was from [emoji6] . . .
Beautiful guys sounds easy will take lots of pics and videos. I’m sure I will come across a few stubborn bolts
Its actually much easier than you think. Just label shit as you go if you want. I didn't. And the loom I got done from Killa was just plug and pray. As I laid it out, everything just went where it was supposed to.
The hardest parts was, which I never did, was the removal and instal of the new mounts to the chassis. The rest pretty much just drops in.
