The panels themselves doesn't matter as the connectors don't change.
When connecting the panel array to the Controller....
If you have an MPPT controller the choice is yours.
If you DO NOT have an MPPT controller they should be in parallel and the same rating as the system IE 12 volt system then 12 volt panels etc.
The 'default' would be a parallel wired connection
Be aware that 90% of the Controllers claiming to be MPPT are not.
MPPT controllers can operate on panel voltages significantly above system and are essentially a DC/DC converter.
