Yep by a member of this forum called Twase, it all works in his GQ and he has the XR6 turbo motor to suit it.
How's this all holding up now @Rocket55? Do you have any vibration at all? Anything you wish you'd done now that you've done it? This is exactly what I'm wanting to do.
I was thinking of sitting an end of my iPad in the recess just in front of the cubby hole. Is that possible with the bits you got?
And ... how do you ever get where you want to go with all those beautiful gals in front of you ;-)
Well finally got round to making up a proper mount / tablet holder. Made up a bracket and adapted it to my dick smith special cheapie, so no more dodgy suction cap. Happy with it but need to see how it goes in the bush.
http://www.nissanpatrol.com.au/forum...016/07/120.jpg
http://www.nissanpatrol.com.au/forum...016/07/121.jpg
You must be following me threedogs, I was going over these thread today as well.
I've used a cheapie holder in another vehicle and need to get something different for the Patrol. The only advice I can offer is, if at all possible, secure the bottom of the actual holder that holds the ipad/tablet, that will make it far more stable.
Check out www.tallonsystems.com I got one for my phone but they also have them for tablets and uses the blank/switch spots. Stable as I've used it off road and everything. A bit pricey but so worth it.
Attachment 71152
It's the clamp looking thing on the left of the centre dash.
I screwed a Ram Mount base onto the centre console just to the right of the A/C / Radio.
Solid as and with a discretely drilled hole for the Charger cable I have it set so I can have maps showing, aimed at me with no chance of it dropping off.
