That sounds awesome, it is good having a yoot.
Agreed brother, Yoots all rock!
GU bastardised heavy yoots definitely need bracing just to get outa the driveway;-) http://www.nissanpatrol.com.au/forum...018/03/266.jpghttp://www.nissanpatrol.com.au/forum...018/03/267.jpghttp://www.nissanpatrol.com.au/forum...018/03/268.jpg
That plate brace for utes is awesome.
I have a gu wagon which I installed the superior wagon specific brace in.
My understanding is that it is stronger than the boss brace.
What a bastard to fit though.
First time might take awhile but after doing say 10 it might be easier??
Hey, @PeeBee, do you have solid body mounts, or does the the floor pan flex where the brace is bolted through?
@mudnut,
the Superior braces are weld in units, PIA to be honest. They are installed external to the spring mount from memory - 15 yrs has past since I did them! The tower link brace is something I designed and installed myself. I could not get the superior brace to fit as needed a 2" body lift, so I installed a flat plate - again from memory, about 100mm wide x 6mm thick. I them used keysteel, circa 16mm thick and accurately located the units to wedge against the edges of the kspring tower. The 100mm plate is feathered on the ends to allow it to jam between the floor pan and the top of the tower. This design locks the tower in place. I then drilled and bolted 6 M12 bolts thru the floor to hold the plate into position.
I have done nothing to the body mounts, all still factory fit. See sketch attached.Attachment 74843
If the floor flexes, it has very little differential movement to the floor brace as this direct 'plane is very stiffly held in alignment.
For sure @Wathog1 good man!
Bent braces I’ve personally seen on some of ours, cracking I’ve seen posted here, there is truly outback horror stories out there too :-( !
Boss braces were included in my Pedders GVM upgrade along with rear braced axle. They are a nice bit of gear and very well made.
@PeeBee Ive just purchased the Superior tower bolt on kit, any idea what time frame it would take to fit with out hoist.
Or am I better off getting a shop to fit them
Apologies TD, been away all weekend, just back. Look can't really comment as my Superior kit was a weld in kit and it took me all day because I made a meal of getting the springs out and back in. I would suggest you get yours fitted or find someone with fingers like a praying mantis from what i hear. Are you buying the kit for the individual tower or the kit to tie the towers together?
TD you have a tray don't you if that's the case jack the rear as high as u can and brace it there undo the tray bolts at the rear and take the wheels off the back and lower it down. The object of the excercise is to be able to get in and line the brake line pad up ,so to do this it takes a bit of bending and prying to get the pad in underneath.Tip: leave front tray bolts done up so as to make it easier to line the tray back up.This is for the plate across both towers.Tip: stock fridge.
