This all that matters. But yes as you know the gauges are a very good idea.
Great to hear it worked out so well 2TROLLFAM. Sounds like you are over the moon with it.
I won't have mine back until tomorrow as there was a problem fitting the exhaust. I had the middle muffler replaced with a hot dog a couple of years ago and they cut away some of the brackets as they were no longer needed. When they went to install the 3 inch zaust they could not secure it properly so they will get the parts or fabricate them tomorrow.
So one more anxious night waiting for my beastie to come home. :animierte-smilies-f
Ok so I'm going for a run up the Toowoomba range over the weekend but for now we just went for a hoot to Minden via back roads which has a pretty steep, relatively short hill near Tallegalla cemetery - a hill that when I hit it at 100klms I used to be lucky to be doing 40 at the top with the trailer on. We doubled back and hit same hill from the Marburg turn off (so dead stopped at the bottom) and all he did was pull the sucker up and we were doing just over 80 by the time we got the top.
So all in all I'm STOKED !!!
Getting pizza in down town Rosewood now LOL then heading home
Attachment 51645
Will be interesting to see what the egt's are at the top doing 80k though
Did Roo Systems say what gains the engine made? Their web site says 35-40% and it certainly sounds like it from what you have said.
Do you have an auto by any chance?
Last I saw it was like 35% chip and zorst only
It will be interesting to see how your fuel consumption goes.
I think the best part is that they can flatten out the torque curve by changing the fuel map so the car will pull stronger from down low. The guy tuning mine said that the factory leans out the fuel map at the bottom to pass the emissions test and protect the DMF and then add more to the top of the map.
It is interesting that other manufacturers increased power outputs on their diesels when they converted to Common Rail but Nissan just kept the same power outputs in the CRD as the Di. Why? Possibly to meet emissions? It really would be good to know what the engineers were thinking.
Brad only had it at 3/4 throttle all the way up and it climbed with acceleration. yeah Brad will hopefully get the gauges soon to know what the EGT and Boost are doing.
Verbally they told me around 35% increase - had to fill out a questionnaire about what I use my car for to determine what tune they did. What I got was a mix of performance & towing capacity because my trailer is quite heavy when loaded but I probably only tow it half a dozen times a year at the moment. The idea, I was told, is to tune the car to suit my personal usage and the the current mods on it. The guys at Roo System gave us their recommendation of a safe level for EGT and boost which Brad asked for as he says if you don't have them how would you know what your engine is doing for good or bad. At the end of the day remapping is a technology based enhancement to my car and if I need to I'll get it retuned.
Fuel economy will be interesting - Thursday is payday and refill car day
And yes, it's an Auto
this ECU remapping has me very interested.
can the ECU stop the egr valve from actuating? thus negating the need for the blanking plate.
also, why do the "chipped" ZD30s suffer so much when towing? is it the tune itself, or are there other shenanigans going on with chipping?
cheers
Hi poindexter. I was told by the people who remapped my Patrol that the ECU part that controls the EGR is locked down by Nissan and can't be altered so you are stuck with a EGR blanking plate. As for chips, I have never had one on my Patrol but I think that its a combination of the chip itself (how sophisticated it is), the setting its on, the weight of the camper/van and how the driver uses the power. So many factors involved its hard to make any generic claim about them. Even remaps, depending on the tune and how the driver uses the power etc could be harmful. But at least the ECU is aware of what is going on in the engine whereas with the chips they are usually downstream of the ECU and alter signals so any safety parameters in the program may be affected.
The Patrol is BACK! At first it did not seem very different as I already had an EGR blank, CC intercooler and had removed the centre muffler so it was breathing pretty freely. I then took off in 2nd (manual) and noticed how easy it was. Almost like a tall first. I can also change up a gear much lower in the rev range the torque curve is much flatter. Around town its much nicer to drive.
Took it on the freeway after work and that's when I noticed the problem. BOOST SPIKES in 4th and 5th gear! Bang Head
Scangauge indicated 22.6psi and I could hear the turbo rattle once it was over 20psi. Car did not feel that great either. At one point the ECU dragged the boost down to around 15psi and the car sounded much better. Since the EGR went in the boost had spiked to 19-20psi for short periods and then dropped to 15-17psi so it was never a problem. Now it tends to hold onto 22.6psi continuously until I back off.
Oh well. Looks like a Daws valve is on the way. Means I can't test with the camper on the back until the boost settles down. Don't want to push it too hard. Pro4x4 can set one up for me but are waiting for stock so might be another week or so.
Finally got my hands on a HPD Dawes valve and fitted it today. Bypassed the solenoid so the Dawes controls everything. No more over boosting and the boost is linear. Car feels very good indeed. More power all round, but does not feel like a V8. Happy so far.
Not has a chance to tow yet, that will be next weekend.
I have not fitted a needle valve yet but the car does not seem to need one.
Well, I finally towed the camper up the hill on the Sturt Highway and it certainly made a difference. Unlike other times when I had to go back to 3rd gear I was able to hold 4th gear going up the hill to the tunnel. I only had my foot down about a 1/4 to 1/3 of the way so was not flooring it. Just driving like I normally would. You could feel the difference, the amount of torque available. Was tempted to floor it but without an EGT gauge I did not want to push the car as it was mid 30's.
I'll have to find the email for you. Got guages today so hopefully he'll find time to put them in soon so will be able to keep an eye on it
Fuel economy is marginally better but we're still giving the poor boy stick that I wouldn't normally. Will have to calm my farm with driving before we could get a decent calculation .. Plus he went for nearly 2 weeks of not being driven while I was in & out of hospital .. Back on Monday for another op so there's another week of being parked
Cheers that would be good :smiley_thumbs_up:
The car does tow very well. Heaps of torque and doesn't drop revs. Towed my camper up the hill on the Sturt Highway in 4th gear all the way. Even though I was in the slow lane and lost momentum due to slower cars in the way I did not need to drop back. I was careful not to over do it as I still need to get an EGR gauge to monitor things.
The only drawback I discovered is that when I put the cruise control on the car starts to surge on and off. Was not towing at the time. Without the cruise control on its very smooth. Seems like the ECU can't make its mind up what it wants to do. It was very annoying. My car is a manual.
2TROLLFAM, have you used cruise control? How did you find it?
Just an update on fuel consumption. Drove from Adelaide to Melbourne and averaged about 12.8 litres/100km. This is about the same as I was getting before the remap & 3 inch exhaust.
Car has rhino platform, front & rear bars, winch, rock sliders and drawers so weighs around th 3 ton mark even when lightly loaded. I was hoping to get better economy but at least its not worse.
