Yeah from what i've seen and read you just need to grind the head off and remove the pins and then bolt the new one on, is that correct?
I did a DIY thread on it a while ago I'll try and find it for you
http://www.ebay.com.au/itm/12V-LCD-D...item2589fe1e5b
cheap enough but I'll get the box size etc tomorrow with measurements and pics
Also where did you get the gauge from? Is it a universal temp gauge?
http://www.nissanpatrol.com.au/forum...emp+controller
Heres the thread the controller is only $16 free post on Ebay
Put the link in the wrong post but this is about ave. price
Thanks TD!
TD has already added a link etc, I just got mine off ebay a well.
I have a small headphone socket next to my engel power socket to the left of the fridge in the back. I used a 90 degree old headphone plug and attached it to the temp probe. The probe is cable tied in the fridge. I can then simply disconnect the probe wire and the fridge power to remove the fridge as needed.
I'll get a pic might make more sense....
Here's a pic of the engel plug with the headphone jack for the temp probe.
Attachment 50102
For all with the older style fridges highly recommend the Digital temperature Controller
I've dumped my 80ltr Waeco's plastic latches and replaced them with 4x 8kg magnets and had it like this for a year now and it's working a treat!
I brought an extra set of hinges for my Engel, so I could hinge it opposite to what they come.
My Engel is mounted on a platform behind the driver, it would just be easier hinged that way.
Then cut and sew the transit cover to suit
