As I mentioned at the start of this thread, I'm running an auto trans with this project and I added a Davies Craig cooler for the trans fluid.
This involved relocating one half of the power steering cooler from the right to the left side and I thought it might be of interest to others how cheaply this can be done.
For those using a manual box, this might also be a handy mod if they want to mount a radiator for a W2A IC.
This is the standard layout on a TB45E..
http://i257.photobucket.com/albums/h...psb0d9b171.jpg
..and this is what we want to achieve:
http://i257.photobucket.com/albums/h...ps2e238350.jpg
http://i257.photobucket.com/albums/h...ps1078f431.jpg
These are aluminium tubes and I have nothing to weld them.. and they are probably too thin for the average amateur to attempt to weld anyway.
As luck would have it, the tubes are just the right size for these 1/2 brass plumbing elbows with the nylon olives..
http://i257.photobucket.com/albums/h...ps5fdcb5fc.jpg
You just need to be able to silver solder a short length of copper tube with 2 copper elbows to join this part here:
http://i257.photobucket.com/albums/h...ps96839e2f.jpg
I decided to retain the original trans cooler and connect it in series with the new Davies Craig. I had to move the original ~25mm forward.
http://i257.photobucket.com/albums/h...psc901ae86.jpg
This is the finished mod. I've been running it now for over 6 months and not the slightest sign of an issue.
There's very little pressure there anyway.
From memory, cost of the brass elbows for this mod was <$15..
http://i257.photobucket.com/albums/h...ps472eb17b.jpg
This is the cooler I used. Bought from Ebay.
http://i257.photobucket.com/albums/h...ps6ed270c3.jpg
The highest temp reading I've seen since is 80C. Before the extra cooler I could get it to ~105C so a turbo installation definitely needs this mod.
Standard temp on the highway with the TC locked is between 60 & 70C which is almost a little too cool.
I'm also planning on removing the cooling pipes that run through the radiator.
There has been more than one report of failure of these pipes resulting in mixing of trans fluid and coolant in both the trans and the engine.
