I need this tool http://youtu.be/LkX638DEsh0
Mine was bent up way worse than that, to the pint with top of the sill whhich should have a right angle was folder and bent up under and the right angle was a huge lip. ended yp cutting out a window in the sill, bent back into shape and cut a section from an old dented door to weld on the inside, still have a bit of bogging to do.
Hit that with a belt sander now mate.
As discussed earlier in the thread the deformation of your sill meant that cutting it out and replacing it with a new section was a good call. What you have done is a compromise and that's fine mate, I made the same compromise on my GQ.
That little spot welder is SENSATIONAL!!!!
Must be the time of year , only small damage , but enough to catch the corner of the door , also found that the brackets for 3 of the flair clips were non existent . So shaped a few bits of pine , glued to the flair , and stainless screwed from behind Attachment 44064Attachment 44065Attachment 44065Attachment 44066
Photo did not attachAttachment 44067
Mate you need this kit http://m.youtube.com/results?q=glue+on+dent+puller&sm=3
It will go to the pannel beaters , when I get sliders sorted !
Ive got my sliders here waiting for me to fix the dents first
Still havent moved or even looked at them yet lol ill start pulling the dent soon though lol
Bolsys are suppling DIY slider kits starting from $300
QUOTE=gaddy;502943]Must be the time of year , only small damage , but enough to catch the corner of the door , also found that the brackets for 3 of the flair clips were non existent . So shaped a few bits of pine , glued to the flair , and stainless screwed from behind Attachment 44064Attachment 44065Attachment 44065Attachment 44066[/QUOTE]
Mate try this method it may just save you some coin also
http://m.youtube.com/results?q=heat+...t+removal&sm=1
Just make sure they are sliders you can jack the car off as I had tjm steps/brush bars and I pushed them into the body doing more damage then good! And they are now bent like a banana
Did you do drivers or passengers?
I only have drivers left...
drivers remaining
IE, i have sold the passengers one.
drivers left just sounds confusing...
I need both lol more so drivers side
lol, just hide it with sliders, worked for me...
if you decide you do want it, just PM me :)
Too easy wont be for a while I am basically tied up working away until August
PM sent910
pics coming.
I took them over a week ago, and I have just had a massive week with work. sorry, I will send them to your PM in 5 minutes once they are uploaded to photobucket.
Cheers, Andy
Did the pics come through alright?
flick me a PM if you are keen and wanna talk price :)
Cheers, Andy
Sorry for interrupting, very rude of me, but maybe we can have some pics also?
http://i29.photobucket.com/albums/c2...ps88ea6665.jpg
http://i29.photobucket.com/albums/c2...ps5804a2a6.jpg
http://i29.photobucket.com/albums/c2...ps63355245.jpg
Not very exciting, just a straight old sill.
Let the bidding begin? :-P
Cheers, Andy
