http://www.ebay.com.au/itm/281162804550?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1497.l2649 Cuppa this is the solar unit I bought, I know you cant see the cable size, but shouldn't I just be able to hook this up straight to the battery? I was going to change the clips (of the solar unit) with an Anderson plug so when I'm charging the battery I can disconnect from everything else. I might draw up a bit of a diagram and post it on here to see if I'm on the right track or if I'm going to zap myself. haha,
By one of those tables , I have 160 watt solar panels, with a 5 mt cable , so I'd need to make sure that the cables are 4mm? is that right?
