Cuppa
To an extent it depends on what you wish to use your 2nd under bonnet battery for. If it were me I'd use a voltage sensitive relay (solenoid) between crank bat & 2nd under bonnet bat, & a Redarc BCDC1240 between crank bat & pod bat. The BCDC will provide up to 40 amps to the pod battery whilst driving, although much of the time the battery in a reasonable state of charge will not accept all of this. (Some folk also wire in a bypass to allow the full amperage from the alternator to fast charge batteries in emergency situations but this is largely pointless with a single 120ah battery). Importantly what the BCDC will so is fully charge the pod battery, something a solenoid (ie. alternator)will never do. (It could, but might involve the need to drive around Australia without stopping!). This will give a significant increased effective capacity. The BCDC also boosts voltage supplied to it if required to ensure optimal charging, Thus it can compensate for any voltage drop between crank battery & pod battery provided the BCDC is mounted in the pod as close to the battery as possible. The BCDC also functions as a crank battery 'protector' as a solenoid does, and is an MPPT solar regulator. All in one small box. The alternative is the CTek Dual, but I have no experience with it. Be careful about buying any other dc to dc chargers. Many have too small output to be useful, & as ,oils ain't oils' not all dc to dc units are the same. I learned of one just a couple of days ago being marketed by Jaycar. It sounds like a great deal & will likely appeal to many folk, who will subsequently be disappointed as although it has high specs (120amps I output I think it was) it is a dc to dc charge controller not a charger. It does not, like Redarc & the Ctek, boost voltage, so in the case of thin wires or low alternator voltage, it would be effectively useless.
Others may comment on what dc to dc chargers they have which suit them.
