Sorry for the bump. But I'd thought I would add some info.
I am a qualified boilermaker by trade, I used to weld on the trains now running around in Sydney. Some points in this thread were of interest to me.
Firstly welding isn't that hard, even for beginners. I understand the points about safety and agree totoally that a smaller project should be used before tackling a larger one that could become a safety issue if not done right. Best to get some experience first. Doing a pre-trade course at TAFE is a great way, I did one myself before I got an apprenticeship and I learnt a lot. It's basically doing your first year as an apprentice at Tafe all rolled up into 6 months, or 12 months if doing it only at night.
ARC welding aka Stick are better suited for thicker material, all most all pressure welding is done via ARC rather than MIG. TIG is the another option, though on steel it's not a good option, better suited for stainless and aluminium.
For manufacturing a bullbar a MIG welder would be fine. In the trade you can weld 10mm-12mm easily with a MIG, although for a standard 240V home supply I think 6MM is the max most of those off the shelf welders can do.
Depending on the material you're welding a few factors needed to be considered. Aluminium for example is so easy to blow through as there is no heat spot visible when welding. Stainless warps easily, as it doesn't spread the heat like steel. Like those stainless steel BBQ's at parks and camping sites always heat up only where the gas burners are but don't spread the heat well to the edge of the plates.
I tried one once while an apprentice, unless you pay the big bucks for them they aren't that good, you can still get flashed from them as they take a split second to darken on you. Using the standard helmet is a safer option.
The flux coated wire is not much different in principle to ARC welding, the wire is coated in a fluxed design to float to the top of the weld to protect the weld from the atmosphere. If I was welding at home with a MIG I would use flux coated wire. Saves on the gas costs. All you need is a new liner for your gun, and a welding tip and you're all set. Just remember you push a MIG (right to left if you're right handed) but drag a stick (left to right if you're right handed).
Not to mention a flash can over time cause damage to your eyes, and a welding flash is worse for your skin than the worst sunburn. You can get cancer from prolonged ray burn from welding, much easier than getting sunburned each summer at the beach. It's a reason why boilermakers on a hot summers day are covered head to toe in protective gear. I've had some bad burn in my time and it's not good.
I hope this post might help those in-experience with welding. :D
