thanks again Nic for taking this on - it is pretty impressive
thanks guys very helpful:)
Thanks, thought provoking and informative.
What about explanining basic 3 to 1 adavantages, or about spliting your load , instead of pulling 1 ton why not only pull 1/2 ton
If you go back to the first page and have another look you will find the answers are there, also the top of the second page posted by EvilTwin also addresses mechanical advantage in basic maths.
Here is a couple of exerts
Snip
Hey Ben i hope the posts above clarify and fill the gaps you were trying to address. All good mate and i appreciate this thread getting bumped as often as you like.
Stay safe this Easter.
Cheers MR
Wow so wot winch systems and gear would you recommend?
Ok yes so all that stuff about degreases is good, some basic load sharing should be placed in hear for example if I was to pull a load that was 100kg and used a simple 3 to 1 I would be only pulling 1/3 of the load there for the load on my gear would only be a 1/3
I do not mean to be backward, I do understand what you have posted before, but I cannot stress how important it is to fully explain your advantages in say a 3 to 1. A lot of people just don’t understand, I do not know how to post diagrams to explain this but I was hopping you could. Just remember there are a lot more than just your basic 3 to 1, these things need to be illustrated so people can fully understand how they work.
I appreciate your input Ben, i have tried to address the 3:1 ratio and the use of a Snatch Block in the post above at the start of the second Snip.
I Highly Recommend that everyone clicks on the link provided by EvilTwin and scroll down to about page 6 where it starts to get really interesting. There are some great pics on page 8
Check it out here Power of the Snatch Block
A great read! Certainly helped me choose the right recovery gear a few weeks ago..
everything goes wrong!
http://www.youtube.com/watch?v=y33vx...layer_embedded
And its That easy folks!!! I bet old mate in the Cruiser rated his ability quite highly, seemed to be a well setup car. Plenty of space cowboys that buy cars that are already modded too.
Shame the guy did not get the whole thing on Vid but certainly a good vid, thanks for posting.
the guy trying to push the navara was lucky he didn't get squashed as well when he started to walk up towards to 80 series, it only needed to roll over again and it might have been goodnight irene. I think navara driver should consider himself lucky buy a lotto ticket for himself and a couple for his mate, plus a few late nights helping his mate fix his cruiser.
I liky this post. Thank you Mudrunner
Great info , But seems to me that the majority of people here have not been in a club or done any driver awareness or recovery classes IMO. You can form a lot a bad habits from not being taught by someone QUALIFIED in this field. Same goes for driving techniques, see it all the time in the bush. so number one attend an accredited course be it recovery or driving, You'll be much the wiser and safer for it, Then you can pass on this knowledge to someone starting out. Just look at the TOWBALL thread. people still dying. do a course and stay safe
Agree about the cowboys to, plenty of cash to trick up a truck but no idea what so ever on how to drive it properly OFF ROAD
Thanks MudRunnerTD ( Darren ) for your post.
Very informative. Of particular interest to me was your highlighting " the weakest link ". I have tried to explain this to my mates ( usually after reaching a higher state of consciousness via the carton of enlightenment ).
Haven't had a lot of success. They argue that because the load on the winch is reduced , likewise on the cable. I usually use the analogy of truckies hitches, Tie one hitch & I can't break the rope. Tie multiple hitches & I can break the rope
Thanks once again ,
Old Wal
Thanks, great explanations
Thanks to everyone involved in this thread. Great read, and some quality info.
So useful for the beginner.thankyou
Thanks, very usefull information indeed. And seeing the Cruiser makes you realise how quick thinks can go wrong. I will buy a couple more snatch blocks.
Look at how far a bull bar can travel when things turn bad.
Got sick of Motorculture so gone back to Tappa
Wow!!!! Imagine being in the way of that!
There is footage years ago of two grey nomads exploring up the NT ,when one got bogged not knowing what to do they hooked strap around the top of the stuck 4x4s bull bar.
Ripped the bulbar clean off the 4x4 not sure if anyone was injured, but pride was surely dented
Thanks for all of this Muddy. So much great information... That is fantastic.
Awesome information that is probably overlooked by so many, thanks I'm learning so much on here
Great write up guys one thing I have learned the hard way is to make sure my winch also has reverse gearing. Puts a nugget in ya pants trying to go down a hill backwards and dropping a few feet from the winch letting go
Hi Kind,
Be very careful winching in reverse down hill. Sometimes it's necessary and such is life but understand what is going on.
A Lowmount winch (98%) of winches have an internal brake inside the drum that functions only when the winch stops. It them holds the winch in the stopped position. Your Lowmount winch actually just let's the brake out a little and when letting yourself down on the winch that internal drum brake gets very very HOT. This is the main reason that Lowmount winches are not ideal synthetic Rope. It melts. A protective sheath is recommended on the first wraps of rope.
If you run a steal cable then its not as concerning. Just be aware. It like riding the clutch or driving around with the handbrake on. It gets Hot. Play safe.
Ime only new to the hobby and was wondering, on the back off the gu above the towbar is a metal loop, is that a good recovery point or should I invest in the towbar hitch????
That's what I was wondering, I will invest in the hitch for sure.
http://youtu.be/a_prLiK97v0
Lucky, very lucky.....
Not to resurrect an old thread, but thanks for this, it's exactly the kind of stuff I hoped to find here . . .
thanks for that. some great info there for a newbie like me
Just found this on you tube. Thought it would be good to post it to show how panic can affect the situation and how easy it can go from bad to really bad.
http://youtu.be/f8trkgFX6wI
Trouble with that recovery was they already had footage of that crossing and decided to have a play, and it went bad
I don't want to sound like a know all, but both their vehicles, especially the 79 are very top heavy. Heavily loaded cargo, roof rack and tiny on the roof as well. Not surprising it took very little to tip that thing over. I know those guys like to take a lot of toys with them, just something to think about that's all, especially if you want to push the limits.
Exactly my thought Rossco. Extremely top heavy you can see how much body roll they are getting on the crossing. The other thing I can't figure out is why were they pulling on such an angle it should have been a straight pull.
@TD: So right, what confused me is he says how often they have crossed it and the fact there was footage of him going over but the one camera man didn't get footage so he decided to go back on top of which he went straight back over the same tracks where he would have known the surface had already been broken.
