Quote:
Lonicus
I don't know if things have changed between the models but the Eonon C1304D I received is a complete piece of crap.
The GPS would sometimes boot up when the car was started, and not at other times. This meant having to do a port scan, resulting in a failure, turn the car off, restart car and GPS usually worked after that, until the car was switched off again.
Thats a pain in the arse...
Quote:
The unit didn't sit flush with the dash, the screen rattled, and the LED lights for the buttons didn't work. Plugging an ipod in meant I had cables coming out of both sides of the unit draped around the gear shift. All in all it looked pretty poxy.
The unit doesn't sit flush because of the surround. I needs a little trim then you can move the unit back...The LED lights didn't work as you need to power them up from the back of the unit, It's not said in the very vague instructions but I eventually found it...Don't ipods have BT?
Quote:
The sound, wow, I haven't heard sound that bad from a stereo since the tape decks I used to run in my old VW Beetles back in the 70's. The radio in my wife's Barina sounded like a symphony by comparison.
Yeah the sound isn't the greatest hey but it does me. I just listen to the radio anyhow...
Quote:
I couldn't stand it, the unit came straight back out.
If I could justify more than double for what i paid for this unit I would do the same.
Quote:
I hunted around this morning and picked up a Pioneer AVIC-940BT. It may not be the best unit around but it is leaps and bounds ahead of the Eonon piece of crap. Everything works flawlessly, the sound quality is brilliant, it sits flush with the dash, and all cables are routed through the back of the unit and hidden in the glovebox.
As others have said, you get what you pay for.
Happy now :)
Good to hear bud. There is a few glitches in mine but I do realise that I have bought cheap so I will get cheap. I'd rather spend 3hunge on a cheap unit and spend the difference between a cheapy and a good unit on other mods to my troll. Because the list for that never seems to end...
