Also if the TPS is not correct the Auto ECU lamp should light on the dash. There is some method to get the fault codes out of the lamp flashes.... but there is a special method to get it into diagnostics mode....
Well I am no expert in this area but I am pretty sure it is lock up as you can count the gears all the way through to 4th then you feel a clunk and the revs drop from 1400 to 1200 which I would call lock up??
The diagnostic mode is not activating for me I have followed the proceedure exactly but cant get a code out. Generally on initial start up the power light comes on for 2sec then it flashes 16times fast with no long flashes, as the shop manual only talks of codes consisting of 10 flashes this has me baffled. An auto expert and a mate at a nissan dealer could not help with this only to say if thay are all the same length that it means all should be ok but it isnt.
Cheers Andrew
Hey mate could it be your torqe converter i know that these can be a real pain in the A#$E when they start playing up also maybe your clutch plates are not letting go Just a thought
Also your bands in your gaer box may need adjustment and a service at the same time that should cost you too much to do that
Or you can just take it to a Automatic specilast as Auto's as you are experiencing can be a pain
