clunk71
I'm not really sure to be honest mate, I'm far from an expert on such matters and am only learning myself....................... like I mentioned before, you may possibly have the same sort of set up as mine, standard duty up from and heavy duty at the rear.............. having a harder set up at the rear will make its back end stick up a bit higher, until you start loading up the boot that is, then will level up.
So you can either change the rear springs to a lighter duty or the fronts to a heavier duty. If it was me I'd leave it............. but that's just my opinion
