Then, it is the second question: How do I open the dash/console to get those things out ?
Sorry, thats not one of ours... Might be the angle of teh piccy but that dash looks significantly different to mine and I also have never seen that particular GPS before either.
For the Aussie GU Patrols...
Check above the heater Controls for 2 small screws and remove.
The trim is then only held in by spring clips. I find it easiest to start at the two bottom corners with a bit of rag over the finger tips. Get your fingers in behind and lever out and up and it will come off. Others suggest try from the top. Either way takes a fair bit of effort.
Yours MAY be similar
Thanks, will try to have a look at it.
Found a picture of the DVD-Rom at the net. But part number tells me nothing. Google takes me only to some Russian part catalogues.
The CD/Radio - some could me it`s a Clarion.
And for sure, Nissan do not build their own CD/Radio/NAV.
