most of the time backfires are associated with ur ignition system
lpg is a hot dry fuel and must have a good spark sourse
check ur plugs and leads dissy cap and "points" most of the time people change the points and not the condensor so check that aswell !
I have a balance pipe that goes from the air box to the back of the convertor.Also the snorkel top is facing backwards.The gas does'nt seem to like the ram effect.
I just bought my TB42 with dual fuel the other day. I haven't driven it enough to comment on consumption rates, but I did have the feeling that the engine even ran smoother on gas. Definitely worth doing if you'r going to be holding on to your car for a long time or you do a lot of travel.
