hey locks,
yes youīre right, the dust is quite bad up here.
have already thoroughly cleaned both the radiator (which is brand new, like 1x month old) and the air con condenser, so, no dust, bugs or anything
and finly:
just to clarify...it does not get hotter when i use the heater
it gets hotter when i:
the ambient temp is quite high...early 30īs and higher
i use the air conditioning (which causes the condenser in front of the radiator to heat up...and my model does not have a thermo fan fitted factory)
i drive at speeds 100kph or over on bitumen
or 80kph or over on dirt
or am carrying or towing a load
or climbing hills
or any combination of any of these
the thermostat is the lowest factory temp option which i think is 77 or 79 deg from memory
temp send unit is factory, never been changed and seems to operate normally, bever had a problem with it
have not seen radiator boiling water yet
essentially it just appears to be getting uncomfortably hot, relatively quickly
i guess itīs just more noticeable up here, because its hotter, more load on the vehicle etc...
anyway, test drive didnīt happen today...
