thanks, i'll let you all know how things go next weekend when i get to removing it.
or burn it out and insurance job haha kidding easy outs are great if used correctly
DONT HEAT THE GLOW PLUG THREAD!!!!!!!!!!!!!!!! it will expand and be even harder to get out heat the area around it
well ive had my fair share in removing broken and busted studs, fittings, plugs and every thing else you could think of, yes easy outs are the go, however dont go the normal ones as these are generally very tapered so before you can get a decent enough bite the hole has to be fairly deep and you will run the risk of breaking through the hole and swarf getting into the cylinder. there are a few sets available that have a more mild taper these are snap on but im sure once you know what your looking for you should get hold of some easy enough but like mentioned before be prepared to shell out a bit for them. http://buy1.snapon.com/catalog/item....&group_ID=1262
also there is a product by loctite called freeze and release that will be helpfull before you attempt to remove it, ive had alot of sucess using this method. http://www.loctitefreezeandrelease.com/
cheers warey
i just did the same thing guys thanks for the help
Gday mate just wondering how you went with removing the broken plug from your 2.8 . I have done one that looks exactly like yours. how did the easy out go
Hi all!
In this case our mechanics use these things.
http://www.nissanpatrol.com.au/forum...chmentid=18939
or
take a strong metal stick (I dislike this word in this case, but I can't find proper word to explain it),then sharpen it for triangle conical shape. When engine is hot, carefully bang down into the hole of broken glow plug and carefully unscrew it. Also I think not bad if put a few drops of brake fluid into the screw thread (NOT in to hole.) for a better lubricating effect.
Hey guys yep ive pretty much done the same thing. Ive tried rost off before an have got some thread extractors pretty much the same as the pucture shown above. But my problem is this methods not working. Will i need to pull out all the steel piping infront of the head for a better chance or is there any other solution other than having it get machined out
try this stye set, they work better on snapped bolts than easy outs ... i hate easy outs they arn't very easy
http://www.ebay.com/itm/Blue-Point-S...-/221720227265
Cheers mate ill have a look
