Good luck with it,and great that youve assistance with the building of it
The good thing is everything forward of the front doors,are the same in SWB/ute/wagon
So parts shouldnt be a problem
The rear canopy side windows and rubbers are usually shot, at this stage in its life
But complete canopies can be had fairly cheap on evilbay
The rear lower tailgate is the same as wagons, so that helps with a replacement
The rear top tailgate window are only for SWB
Sit back with an ale or two or 4
Write a list of ALL the things that you think need replacing
Then look again a week later, make sure your on the right track
Dont throw anything out no matter how stuffed it is till the replacement is sourced,sometimes that bit ya throw could have that , screw,bolt,nut whatever that the replacement doesnt
Tim,is on the money re spending twice
Alot of the smaller parts postage costs anywhere in australia isnt to bad to your door
The larger parts, best to buy local to yourself
Tim,should be good for the smaller stuff
But larger gear ive a few MQ/MK parts contacts living in the gippsland area in VIC, that could help
