I did a quick Google search and found that 4WD Systems sell them, and I also read a while back that Enzed were selling them. I got mine from Berrima Diesel about 8 years ago.
Can't see why you couldn't use two in line.
The original filter is on the pump suction
The new filter separator will also be on the pump suction doubling the resistance,
it will mean as either one or both filters gets dirty you will slowly loose throughput and power
How ever I fitted the same set up on my 1992 Hilux in 1994 and have not changed the factory fitted filter since then!
I did however fit a new factory filter in 1994 when I fitted the CAV pre filter/separator setup
I clean the glass bowl every 6 months and get around 10 - 20ml of black sludge and around 3ml of grit out of it
Change the filter around every 2 years or 40,000km and no problems in all that time
The set up on the GU will be treated the same
Interestingly the Hilux has spent it's entire life on the east coast and I get fuel from high volume fuel outlets
Still get sludge and grit though!
We did get a load of wet fuel in Sydney (Kellyville) last year when we had a Rodeo and it stuttered on every hill at full throttle till I drained both filters and go rid of the water! (seems thenflow rate was high enough TO PASS THROUGH the Rodeo separator
That's why I fitted the pre filter separator on the GU
Joe
Hubby has decided to fit the filter under the bonnet and cant prime the new filter. What would be the problem?
this might sound silly but they do have an in & an out so is it inline facing the correct way?
Other then that check for air leaks in the fittings & the assembly itself.
This is the way he has fitted the hoses. Number 2 is hooked up to the tank and Number 4 is hooked up to the original filter.
That looks right so what has he tried to do so far?
He has just tried to prime using the original filter primer.
Ok I made a call to Tony to confirm what I was thinking & it may pay to wait until someone else to come along & have some input here as they may have a trick or two up there sleeve but I would start with filling the new filter with Diesel as a start.
Hi Snicko
As you have placed the filter separator under the bonnet this will always be a problem each time the filter is replaced, (unfortunately you can't fill the filter as the fuel gravity flows back to the tank)
However it is quite simple to fix in a few different ways
1. Remove the fuel line from the outlet of the original filter fit a long length of fuel hose to it (say 1 metre) and suck the fuel through, then place hose in a plastic bucket and prime till air stops then re connect original fuel line
2. park on a hill facing down hill and when all fitted up start engine and drive away, the engine will run for a while then flame out on fuel starvation then re start as the fuel comes through
(Only works for manuals)
I use both methods as I have only manuals and live on a very steep hill
Good luck
Joe
