found this in one of my old text books
1.Set up the meter for a continuity check
Make sure there is no power connected to any circuit that you test for continuity, then prepare the Digital Volt Ohm Meter or DVOM for testing voltage by inserting the black probe lead into the “common” input port, and the red probe lead into the “Volt/Ohms” input port.
2.Check the meter function
Turn the rotary dial of the DVOM to the mode that includes the term “Continuity”. The Digital Display should now give you an ‘Out of Limits’ reading indicating that there is not a continuous circuit connection between the two probes. Touch the probe ends together. The display should now give a zero reading, which indicates no resistance. This means that there is a continuous circuit through the probes. Some meters also indicate continuity with an audible tone.
3.Check a fuse
One typical use of the test is to determine whether a fuse needs to be replaced. If the fuse has been overloaded and ‘blown’, then it will no longer complete a circuit when a DVOM is used to test it. To check this, place the black probe on one end of the fuse and the red probe on the other. If the fuse is functioning correctly then the reading will be zero, indicating a complete, or closed, circuit. If the fuse is open, then there will be no reading and no tone, indicating an incomplete, or open, circuit.
4.Test other components
A continuity test is used to check for a broken circuit caused by a break in a cable or lead, or caused by a component becoming disconnected. The same test can also confirm whether there is continuity between components, which are not supposed to be connected. When this occurs, it is known as a ‘short circuit’. This test can also be used to check circuits that are suspected to have a high resistance
