I just have the earth disconnected when the Patrol is sleeping in the garage and connect it back up when i want to take it for a burn...
I was thinking that might be the case, but just wanted to be sure and thanks for the info it confirmed what needs to be done.
Cheers mate.
Actually i was thinking along the same lines if it becomes to messy
Hi PeeBee
What switch did you end up useing, i never thought off the load being used to start up
Well i found two faults pulling fuses, one was a wiring loom to a old lightbar with an inline fuse, fixed
the other is a fuse Attachment 88626 for some reason highlighted yellow says ( Battery 7.5 amp Elec Parts ) so i pulled that one as well
So my Paracitic draw has gone all good but i have not found anything that is not working (as yet) that is run from the 7.5 Battery Fuse Elec Parts and why is that fuse highlighted
Yellow i am sure there must be a reason, has anyone had issuses with this fuse. Its the last of the 2006 models literally one of the last ones built Dec 2006, no computers i believe, no NATS Immobilizer (nervously removed with very big hammer and screwdriver when i shit it self ) and the light is still flashing under dash matt ? but that fuse is a mistery at the moment.
NATS just when i thought that problem was gone, i believe that fuse is number 24 and i think it is part of the NATS system which got the hammer so mabe it's confused i dont know
i will just have to wait and see.
