http://atocauto.com.au/proddetail.asp?prod=KNGUFDH
http://www.patrolapart.com.au/produc...t-door-hinge-2
I need to do all my doors where do I get bailey channel? Clark rubber?
Not sure, Rare spares ????
Check this out
http://www.clarkrubber.com.au/bailey-channel-seals.html
retuned tv and still cant get bailey channel
OEM only for the GU's healy. They are a moulded type of channel. Not like the Q's where anything fits. But having said that, the drivers door window on my GU would rattle when down about half way. I noticed the front section of the channel, just before where the channel turns 45 degrees and up the front of the door, it was very worn out. So heres what I did.
- Remove window from door
- Remove the regulator
- Remove the front steel strip which holds the bailey channel in place
- Took the strip to CR to get the right sized channel.
- Got home and had a beer.
- I then removed the old channel up to about half way up the 45 degree section
- and cut the old channel off just before the first bend ( this section is covered by both mirror mount and a plastic cover on the inside
- Inserted and cut to length the new bailey channel
- Glued the bastard in.
- Had another beer.
- Put everything back together and had more beer to congratulate myself for not spending $150 on an OEM channel, but $12 was spent.
Hey man thanks for that
Never would have thought of clarke rubber. As far as the hinges go i spoke to the ferret last night and he no longer does the hinges but they are on ebay, around a hundred dollars a door for the good ones
