BrazilianY60
Well, ATF is not the only recommended oil for the TC, by Nissan's standards. I interpret this recommendation like this:
If you have an AUTO, then use ATF on the TC just in case seals fail between the AT and the TC, no harm is done.
If you have a MANUAL, then use the GL4 stuff the same as the MT, so if seals fail, again, no harm is done.
If the GL4 stuff (90w75, etc) is too thick for your location temperatures, then it may cause this that we are talking about. Just change to a thinner oil on the list (as long as it is GL4) and retry.
