What spec is the injector pump timing set at?
Who rebuilt the engine?
Injector pump timed at stock spec, I forget what it is now. I have tried advancing it and retarding it which made no difference to the noise
Rebuilt by some bloke on the goldy that does td42, 1hd
Ok. I have seen engines tick when the rings were tight in their lands after a rebuild. Could be something worth checking.
What would be the process in checking that? Should I contact the rebuilder or can I check that myself? I have also just checked my catch can 4000Km after rebuild and I was surprised that there was actually a bit of oil in it since its new I thought there'd be no blow-by.
Have you checked if the power goes off from glow plugs. Constant power on glow plugs caused a rattling noise from my td42...
