i hit a bit of battery going flat in hybrid cars if they sit, the start battery goes flat, takes about 2 weeks, i've run parasitic draw tests etc, never found anything out of spec, but new cars run some things even when off, so i did some digging as i had access to dealer info, yep 10 days sitting still was all they were designed to last ( not nissan but i doubt it would be very different ). they would throw codes but these turned into dead ends was a list of codes for flat battery. the best we could say was dont keep the key in range and drive it every few days or charge the battery. 0.2 of an amp is what we would see after the car had shut down. this probably isn't your problem but most new cars will flatten the battery quicker than the older cars
