Haha tried that.
I would say yoy have a boost leak for sure. That explains the lack of boost and the black smoke as it is tuned for more boost so over feeling now. I woyld be tracing every boost hose looking for a split or blown hose . You may fine it just with the bonnet up and someone revving up the car.
Big Stogie Cigar trick possibly Mark Mate[emoji106][emoji106]
Smoker or not, fill your cheeks with a massive cloudy gob full and pressure witness visually test that aluminium radiator thingy [emoji23]
Have you taken a reading directly from the compressor with the wastegate firmly closed?
Connect the gauge hose directly to the compressor housing outlet and remove the hose on the wastegate actuator.
Don’t go silly with it in case it boosts high before it overcomes the actuator spring
The compressor outlet will currently be connected to your boost controller which then feeds back to the actuator.
I assume your gauge hose is connected to your IC or manifold?
Yes my gauge reads from a port in the inlet manifold. Then another port T'd (one to the injector pump, one toward the boost controller), then to another T, (one to the boost controller and the other to the wastegate actuator) Apparently its plumbed like this for high boost applications.
So what should i see doing as you suggest John? What shouldn't I be seeing?
