The first thing I will say is I have never worked on a ZD30 CRD so this information is assuming the VNT turbo setup is the same as the DI motors.
There is a couple of different ways to control the boost
1) Adjust the boost limiting grub screw. By my way of thinking not ideal as it may also slow the rate of spool.
2) Fitting a dawes valve on its own in conjuction with the factory boost control. This still gives the engine computer control of the boost but eliminates overboosting. This is a good method if you want to keep a functioning EGR system as it lets the computer reduce boost to allow the EGR to work.
Attachment 6548
3) Fitting a single stage dawes and needle set up. This gives full manual boost control, the computer is no longer in control of boost. The dawes sets the maximum boost and the needle valve contols the rate of spool.
Attachment 6549
If your post turbo EGT's are hitting 700 you need to be lifting off the accelerator, those temps are WAY to high. Don't let the EGT's get over 550.
Reducing boost will make the problem worse, diesels run hot when they are rich - the opposite to petrol engines. You need to be aiming for a constant 17Psi boost not the erratic boost you are currently experiencing.
Tony
Thanks to CHAZ for the images.
