WARNING  explicit blighty content ??
		Funny old day, had to go back to work :furious:
Don't know how you guys are doing down there but Wales is just lifting lockdown :(
Consequently didn't get much done on the Trol but did start attacking my Y61 back axle.
I bought GU Y61 axles years ago for the 4.6 diffs, then stored them under plastic covers. Seemed like a good idea at the time but the plastic let the rain in and not out, causing some spectacular Titanic style rust :frown:
It was that bad I was able to rip off the top arm mounts with my bare hands  and didn't even take a pic Bang Head
Here's the first pic I took when I realised
http://www.nissanpatrol.com.au/forum...2020/06/95.jpg
Warning, the next shot is pretty grim .....
http://www.nissanpatrol.com.au/forum...2020/06/96.jpg
Anyway in pure optimist mode I continued
http://www.nissanpatrol.com.au/forum...2020/06/97.jpg
Slider pins still worked and there's loads of meat on the pads ;)
http://www.nissanpatrol.com.au/forum...2020/06/98.jpg
Nice bit of patina showing up now
http://www.nissanpatrol.com.au/forum...2020/06/99.jpg
Maybe just maybe I'll get away with it after all ? Here's a section with the top arm mounts removed and a bit of 40 grit flap disc action. Could do with 4 grit really ;)
http://www.nissanpatrol.com.au/forum...020/06/100.jpg
I'll be making the rear suspension a 4 point set up and bracing the casing , or whatever you lot call it :xxxx:
http://www.nissanpatrol.com.au/forum...020/06/101.jpg
Sand blasting next week so gotta get this prepped a bit more before then.
Lockdown in Wales is lifting, did I mention that :oops:
