How many kms?
Following is based on my 08 CRD experience:
ProVent 200 Catch Can
3" h/f exhaust (cat/muffler), many types available DEA, Redback. I use Berklee SS
EGR plate(solid) _ block both ends of EGR assy (@ exhaust and inlet manifold)_Common that EGR pipe running behind back of motor splits and will be of no concern. Do exhaust manifold end at same time as installing exhaust.
OBD11 scan tool_Maybe UltraGauge EM Plus or MX. I have EM Plus_both good for performance monitoring and needed to clear trouble / fault codes.
http://ultra-gauge.com/ultragauge/ultragauge_wired.htm
Install boost controller, many types available, the Dawes(3 bar racing) or Tillix are two I have used. Both good(currently use Tillix). Can install needle valve to control spool rate but CRD can run max spool (no needle valve required) or U can run the boost controller in conjunction with OEM VNT vac sol.
They need to breath well. Would consider air box upgrade and pipe upgrade to 3" from airbox to turbo. Not necessary straight up but when it is time do it right.
TIG welded intercooler_Worth looking @ Cross Country Upgrade intercooler(tube and fin). Maybe PDI FMIC - (both $1600). Thing with PDI FM (bar and plate), it is a tight fit with genuine bull bar but doable.
http://www.crosscountry4x4.com.au/4w...er-detail.html
https://www.performancedieselinterco...ercooler-yccjj
Interesting when I opened link, was surprised as the installation pics are of my install that I sent PDI.
If FM cooler is of interest have a read of following link from post #22 of my PDI 600x300x76mm install:
htthttp://www.nissanpatrol.com.au/fo...-CRD/page3p://
Not needed straight up but there are benefits with ECU remap.
