It is a good question, the larger core and non-exchange basis can explain away some of the extra cost but it still leaves a lot unaccounted for. I wouldn't be trying to get one if it wasn't for a generous tax return this year. Will make sure to do a thorough post when I get the thing
i have the crosscountry ic and works very well. I could be wrong here but the are ic with the optional bigger scoop may be illegal in some states as the taller scoop may affect vision.
3 Attachment(s)
If I got pinged for the taller scoop I'd be asking why, does not affect forward vision in any shape or form.
May be passenger car law, like reverse mounted scoops being illegal.
Just purchased a fully tigged IC from Diesel Smart, under $400 changover,
Pressure tested to 60psi,
33% bigger
And 5 year warranty
No alterations, very impressed, You'll know their IC as it'll have pic of my motor.
I have no affiliation with DS.
And totally agree with Mudski on the price of some Intercoolers.
Try pricing some cores, You see how much your ripped off.
Diesel Smart do a change over IC as well
Check out an IC from an XR6 ford, will need WRX style scoop though
$1300 plus just to have EGTs 50 degrees cooler than mine, what for that's half a diff lock LOL
1 Attachment(s)
i think ARE and cross country are good brands regardless of price and which ever you choose is a personal preference. what ever you choose is got to be better than Nissan's. but with ARE ic i'm not sure on the scoop. i must admit that what i have read about the scoop sounds likes a very well tested product however I know for a fact that in QLD, modifications to vehicles need a mod plate. how I found out was I changed troll into a 2 seater having storage draws full length to back of the front seats. when getting this past by a modification plate inspector he told me my long ranger fuel tank needed one as well. reason is any mods need a mod plate to legally registered, and may well do with insurance claims in the event of a accident if determined to have contributed to it.
I have the same scoop as three dogs has, does not block my vision at all
Also does not make a huge difference anyway.
I went with the ASE, I didn't like the CC as I don't believe that a pressure vessel should have sharp edges. I was very happy with the ASE although I guess it's hard to say categorically without an IAT gauge.
2 Attachment(s)
Just an Update now I've had the new Diesel Smart IC fitted, I also have the larger scoop.
First I drove so get some fuel figures, managed to return 12.8 around town. Now I'm driving it a bit harder
and noticed boost was very high 15psi at 100 kph, due mainly to leaking IC not leaking now. I've reduced boost to
10psi at 2000rpm EGTs are low and stable . Have some steep hills over our way and can floor it from the bottom and EGTs are fine.
Happy as a pig in poo. If you after and aftermarket change over IC I would recommend Diesel Smart, change over for around $400
gotta love that
3.0 intercooler
Hi guys
I have a 2001 GU. I have been told my intercooler is leaking. Is there a way I can tell for myself. My concern is weather its the intercooler or the turbo
An introduction thread gets you better answers mate. Look for oil spray along the crimped edges also a boost gauge would help too. Being so old no doubt the factory cooler s leaking but the turbo would be close to its end too.
Yep an upgrade to my intercooler sure made a difference - between 80 and 120 degrees over the entire rev range. The included fan turned out a huge help when on the beach or up slow moving tracks. You just don't realise the heat soak on the stock units. I kept the same footprint size on mine but increased the scoop size. Well worth it for the decrease in exhaust/engine temps :thumbup:
