May pay for you to check your power steering system for leaks, especially around the hoses and the pump front seal.
Turns out I do have a leak in my power steering, where it appears to housing join on by bolts. (Pics can be supplied if needed) is there something I need to worry about or is this normal. I'm not sure on the rate of how much oil I'm loosing yet but have just topped up and will monitor over the next few days. Looks like it has been leaking for a while.
Sorry I am not real sure what you mean, are you saving it is leaking from the pump housing or possible one of the banjo fittings where the hose connects to the pump?
It doesn't really matter just make sure the bolts are tight, wash the area down and keep on eye on it.
Leaks from hoses and the pump front seal are the ones you need to worry about.
Just keep an eye on the fluid level.
