I went a slightly longer route... I ran the tube along the LH chassis rail and when it hit the radiator mount panel curled it down and towards the plastic wind deflector under the radiator shroud. The hose is on a slight downwards run all the way and can collect a goodly amount of oil with no chance of the truck sucking it back if you forget to drain it for a while. I just cable tie it behind the end of the plastic so it cant be ripped out.. One last thing for engine safety is I silver soldered the end of a standard airline fitting (same thread) and wound it in as a bung with some sealer tape. There are two benefits here, 1. cant suck in fresh air or water if you forget the close the spigot (it's a sealed surface), 2. protects the ball cock from dirt and crap .... when i drain it, i just cut the cable tie, drop the hose down and take out the bung and drain, once drained, return the bung and re cable tie....
