thanks everyone next chance i get ill pull each kingpin plate out one at a time and clean them off and use one of these needles to re-grease them.
will the bearing need to go back in at the same spot? meaning is i pull the plate out and the bearing gets spun 90-180 degrees and put back in would that be bad?
im thinking if this happened the bearing would be contacting a new area on the race.
