Ultimate Life Hack
http://www.nissanpatrol.com.au/forum...020/09/157.jpg
Ultimate Life Hack
OK this might not be new to you but I just learnt a new trick and was amazed how great it works when rotating wheels/tyres. Remove wheel, shuffle replacement wheel/tyre into place, then instead of heaving the thing up in a crouched position, then trying to rotate it around so you get a stud through, and busting a pooper valve in the process, do this: Shuffle replacement wheel into place. Slide a spade/shovel under the outer edge of the bottom of the tyre. Push the spade/shovel handle down, thereby lifting the wheel up an inch or two to stud height. To rotate, slide the spade/shovel handle left or right to spin the wheel until studs line up with the holes. Push the wheel on. So bloody easy and takes no effort at all!
Thanks to my old man I will use this trick from now on.
When out bush with poor radio signal (am/fm), knock a tent peg into the ground and pour a billy of water over it.
Hook a jump wire between the radio aerial base and the tent peg.
Works brilliant most of the time.
Just saw this on Facebook..
Nice little life hack.
Jiggle a zip tie through that tough knot...
This will give you loops and the knot should come apart simply.
http://www.nissanpatrol.com.au/forum...2021/07/67.jpg
http://www.nissanpatrol.com.au/forum...2021/07/68.jpg
http://www.nissanpatrol.com.au/forum...2021/07/69.jpg
Bastard fuses, fat fingers and no fuse puller?
https://youtu.be/JRUC4fVvs28?si=rwL7JedYzlWMYLiC
