Has not been a lot of info forthcoming.....
Mark, interested re: your 180RWKW, what N-m are you getting and from rpm?
you must be pleased with new eng mate.
Tbh mate. I cannot remember. I took pics of the. Report on my old phone. That does and took maybe 700 photos with it that were on a separate sd card. I should have backed the card up to online storage but I didn’t so I lost a lot on that phone.
But yeah I am happy. It does have its niggles but overall I love it.
All good, just fitted procharge stage 3 turbo to CRD, need to sort low down torque more, been playing with actuator rod length for quicker spin low down. Do tune for more fuel as well next week, Max B 23psi good run and improving numbers (140-150 rwkw/374N-m), to be confirmed next week. Moves out >2300rpm.
[QUOTE=Bidja;760090]Has not been a lot of info forthcoming.....
Thanks fellas I’ll get onto that ASAP and let you know how I go 👍 cheers
Just fit a needle valve then it only takes about ten seconds and you have adjusted the turbo spool up. 140rwkw are pretty big numbers for a 3ltr. Be careful. I think my old Di was around 125rwkw before the pump shat itself. But I do know not that when towing, the TD just pulls like a freight train and I rarely need to change out of 5th. Different story with the Di...
Yeh, have full manual boost control, last yr actually got dawes and needle of you. Now trialing Tillix (both good kit). The main deal with the Procharge stage 3 turbo is that it has larger 10 blade exhaust whl that take a bit to spin up. Reason for actuator adjustment is to hold veins closed longer low down to get it to spin up earlier to bring on boost (even @ max spool), and also looking at extra fuel low down to help out (ECPT Tuggerah, NSW will dyno tune). Run full NADS, 3" Xpipe, ECU remap, TIG I/C, 3" Fabwitz induction, Gauges boost/EGT/Oil Press. Some CRD produce 200rwhp/25 psi max B but not going there..
Your torque low down would be a delight.
