Our local tip has a full weighing system in the entrance bay and exit and they detirmine the cost by the weight difference. Not sure if any other tips in your area have the facility.
Here's a picture of a 2" GU lift on a GQ so a standard 2" GQ lift would be slightly lower.
They are 31" tyres and even with the higher 2" lift (more like 2.5") it still doesnt look silly...
Attachment 4683
I love my 2" lift. I have to lift a cheek to get in and out. Makes it feel like a truck. lol
Hiya Rick,
Going by the highlighted info there is no need to "lift" the truck. Returning the suspension to normal spec from sagged (my old GQ was an ex Horse Floater as well) will lift it about 2 or even 3 inches from what it is now back to standard height.
The lift will give you no increased ground clearance as the diffs are still were they were before. You will get a slightly better entry and departure angle however ramp over angle may be similar depending on circumstance.
Lifting will also raise fuel consumption slightly due to an "apparent" aero increase to the frontal aspect and some vehicles require castor correction kits even with a 2 inch lift and some don't. 1 of mine did.
BUT...
If the cost of the suspension components are similar in replacing the stuffed bits with stock height as raised height gear then a lift may be the way to go.
Just ensure that a soft 2 inch lift isn't lost with your load compared to a standard height +200 Kg as if you end up with the same departure angles etc then there was no point. Patrols have a lot of body roll anyway, esp so if people disconnect the sway bar as the two inch lift takes a fair bit out of the rear geometry unless Sway Bar Links are extended or extension brackets fitted so sometimes a firmer suspension is a lot better
The big thing IMHO is that with the destinations you have planned (all 'cept Mitchell are reasonable tracks) get the best Shockies you can. A couple of those tracks are shockie killers.
